Can I set up my Thunderbird email client as the default within MS Excel so an email hyperlink clicked within MS Excel opens my Thunderbird Email?
  • 5 replies
  • 6 views
  • Last reply by Zenos
Hi, I want to be able to select a hyperlink within an Excel spreadsheet it hyperlinks to Thunderbird. Right now it hyperlinks to MS Outlook. Is there a way to change settings to get the hyperlink function to work with Thunderbird? Thanks!
All Replies (5)
https://support.mozilla.org/en-US/kb/change-program-used-open-email-links
about halfway down that page is how to change the operating system's default mail client
Thanks for the response, but this didn't work. I do have Thunderbird set up as my default email client, but apparently excel doesn't recognize it, and still tries to open ms outlook, which is a problem because I don't have outlook installed on my computer.
Out of curiosity, what kind of "hyperlink" is it that would launch an email client rather than a browser?
I was thinking that Thunderbird doesn't do MAPI, but see this:
http://kb.mozillazine.org/MAPI_Support
I know about mailto:. I wanted the OP to tell us what he's using.
